1 - 4 of 4 Posts
Hi
1.5 dooper 2015
I’m getting 290B00 fault code in bimmerlink.
“Air system egr plausibility……”
Sometimes I then get 2AB500 “boost pressure sensor….”
Can anyone advise how I can use BimmerLink to narrow these faults down to help identify exactly what is causing the fault please?
Thanks in advance
Bobby
Worth checking this thread as I did previously have to clean the offending pipe: Cooper D engine light help
I gave the car a full service oil, +oil, air and fuel filters. Ran through Egr cleaner and cleaned map sensor and, touch wood, no problems since.
Could be worth starting with the above thread as that problem appears to be quite common. Good luck 🤞
1 - 4 of 4 Posts
