I asked my dealer about this as the 12v power source is controlled by the ignition... but it stays powered for about 8 minutes after the car is locked.Hi
Is the 12v supply under the radio always live, or only with ignition on?
Cheers![]()
Hi, I expect that tapping into a light feed will at best blow a fuse, and may upset the operation of the lights. Sorry I don't have a positive answer, and you're doing the right thing asking - don't guess this one, it won't end well!In the rear of my 2016 F56 I have a spot to put in an aux 12v socket. It is a spot intended for the Storage Package plug, but is just a cover for the cars with out the storage package. I have the socket I need but no directions for wiring. Can anyone tell me if it would be OK to wire the plug to the light, which is right next to that location, in the rear on the right hand passages side of the trunk area??? Or better, what or where I SHOULD tap into. I successfully opened everything up and found NO open / available plug / wires to tap into, just tons of wires tapped together in bundles? I know I need a Hot and a Ground, but which ones?? I do not want to splice into just anything, and make a huge mess. I am sure that SOMEONE else, much smarter than me already has accomplished this??
If they did that might be market specific. My 2015 has the storage package with the 12V boot socket. The boot socket still shows up in the storage pack on US spec cars.As far as I know they stopped fitting a 12v socket in the rear over a year ago on all Gen3's regardless of what package you have, mines a Now 2015 and not got one!
I certainly won't tap into a lighting circuit, you'd be getting all sorts of issues I'd say!
There was a thread on here recently about this so a search could answer you question![]()
Sorry I was referring to GB registered/spec'd MINI's. When I was looking around and deciding if to buy one the demo's I tried had the socket, secret glovebox & side sun blind but gone time mine was built!If they did that might be market specific. My 2015 has the storage package with the 12V boot socket. The boot socket still shows up in the storage pack on US spec cars.
Jealous big timeI've got one in my boot & mines 16 plate![]()
Jealous big timeI assume it's not hidden somewhere like under the false floor etc?
They do muck about with spec's a lot!
I wanted it for the coolbox instead of draping the cable to the front!There is one in our clubby in the boot and one for rear seat passengers too. Awash with them! We will definitely use it for our powered coolbox!
Oh now you tell us! Just spent 10 minutes outside in the minging weather looking for it! Mine's there, up by the light. It came with the storage pack which is included in Chili on a JCW. Maybe still is, my car's brand new.Beside the boot light same sort of cover as the front one
Although I'm not sure I'm ever going to use it![]()
