1 - 9 of 9 Posts
Hi,
2016 cooper convertible petrol with auto air con Is not blowing cold.
Its been regassed with y1234fy. All 3 fuses related to ac are ok. If I disconnect the air con pressure switch the radiator fans run at full speed so that seems ok.
I can’t tell if the comp is engaging. I’ll get underneath later and remove the panels to check
Any other ideas please?
are there Switch in the convertible Roof that turn off air con?
thanks
Darren.
Cooper S Works 210
There's a fuse panel behind the glovebox, remove the panel inside the glovebox to access it. There's also a fuse box under the bonnet
Here are some pics of the fuse layout, looks like air-con fuses are F34 (40amp), F63(5amp) behind glovebox and F29(5amp) under the bonnet
69855
69856
69857
Discussion Starter #4
Thanks for the reply. I only have fuses in the glovebox, there aren’t any under the bonnet. All 3 related to air con in the glovebox panel are ok.
the paper in the fuse box doesn’t identify the air con relay.
69860
Discussion Starter #6
Still haven't found the compressor relay so I'm going to pull the plug on the compressor and check for power with the AC button on/off. I'll also take tension off the serp belt and check the clutch is engaging ok.
Thanks for the link to the diagrams, these are a great help identifying parts. 👍
Discussion Starter #7
Air con compressor clutch is not engaging. Difficult to access the plug to test the clutch?
Any recommended apps to read live data from the air con system? Tried Bimmer-tool but it doesn't have live data from air con.
Cheers.
Discussion Starter #8
Three wires on the compressor red, black, brown.
12v across red/black gives faint click like a relay operating.
12v across black / brown, nothing.
Could do with a wiring diagram too.
Hi,
thanks
Darren.
how can you drive while air cond is off? don't you die from heat?
In my wife's mini, the radiator is shooting so hard that if we turn of the air conditioner we are getting toasted inside in like few minutes.
1 - 9 of 9 Posts
