Yes will be lease, in the past I have lowered lease cars and put back to standard springs before giving it back. Its purely for aesthetic reasons not performance.Is it a lease? If so the lease agreement will probably state you can't modify it as its not your car.
Brake mods? Or just calliper paint (as I intend to do)?ST XA Coilovers specifically for the SE (same internals as KW V2 as same company). All mods declared for insurance.
Any full side profile shots, keen to see the clearance from the floor to the batteries, does look good, but as said I would be happy with a subtle Eibach spring
I’m all about the subtle mods. It looks amazing. No idea how I’ll get away with it! 😂
Looks ACES now!
I think the usual would apply, coat the body of the coilover with a ceramic coating (I use Carbon Collective) and then make sure the threads are greased. Difference between KW and ST is the body material (internals are the same).FWIW, I used to raise my ride height in November and lower it again in April (we get mountains of snow and ice here). The B14 was a bear to adjust. How easy are the ST?
The front are super easy to adjust up or down but the rear takes more work. You have to put the car on jack stands in the rear and disconnect the lower bolt on the shock/damper. You also have to disconnect the rear sway bar end link. This allows you to then lower the trailing arm so you can remove the rear spring and the spring perch which can then be adjusted.FWIW, I used to raise my ride height in November and lower it again in April (we get mountains of snow and ice here). The B14 was a bear to adjust. How easy are the ST?
