Yep......along with the threaded hole for the driver-side punch out in the bumper.
Mine has this, but don't most of the rear mounts require both mounting (screw) holes? This only has the passenger side hole, the other side is just a metal plate, with a small square/rectangular hole.You can buy the genuine bracket to go behind the bumper,so the genuine bike carrier will fit, but cannot yet get the wiring kit for the bike carrier lighting.
BMW have told me if I fit my own wiring kit it will void the warranty for the cars electrics
http://www.realoem.com/bmw/enUS/showparts?id=XN92-EUR-10-2014-F56-Mini-Cooper_SD&diagId=51_9197
If you look at the link you can buy the bracket with the two threads picture only shows 1 but parts numbers are for 2, remove the bumper replace your bracket with the new one, then you can use the genuine rear mount bike carrier, the only thing they don't make yet is the rectro fit wiringMine has this, but don't most of the rear mounts require both mounting (screw) holes? This only has the passenger side hole, the other side is just a metal plate, with a small square/rectangular hole.
