1 - 9 of 9 Posts
Hi can anyone tell me if bimmercode will enable to change 3 second indicator sweep to longer?
2020 Moonwalk Grey LCI F56 S (Salt) (Current) / 2006 Pure Silver R53 (Hot Chili) (Former)
I can confirm on my F56S 2020, it did both. Enables the option in the standard UI and as a "hardcoded" option.
I have a 2016 F54 Clubman. Bimmercode gives me an option to change from 3 to 5 flashes and it appears to code. However, the car always remains at 3 flashes.
I believer there is a BMW MINI software setting (currently) that prevents the change.
Discussion Starter #5
That's what happens with mine .. it stays at 3
It might be controlled based on location. My old 2015 F56, 2018 F54, our 2019 F56 and my new 2020 F54 all allow changing from 3 to 5 flashes.
There 3 different way to change from 3 second indicator to 5.
If your car has new UI but lock on 3, you can FDL code NBT on this "5_FACH_TIPPBLINKEN" to "aktiv"
If your car is old(before 2016), you need to FDL code BDC on this "BLINKZYKLEN_ANZAHL_TIPP" to"04"
If your car is old(after 2016), you need to FDL code BDC on this "PIA_DEFAULT_TIPPBLINKEN" to"Tippblinken_fuenfmal"
My 2016 F57 Cooper Convertible only allows 1 or 3 from the dashboard UI. I just used Bimmercode version 3.5 to change several coding options last week, and the only indicator options offered were to change how many times to flash on locking/unlocking.
1 - 9 of 9 Posts
