1 - 3 of 3 Posts
Hood is close but keeps getting hood open light and ''bong noise'',is there a sensor?
I had change a latch but not sure whats the problem
There's a contact such on the
There's a tailgate switch on the bonnet catch that sends a signal to the BDC/CAS to confirm the switch has been activated thus closed.
If you're light still shows open, then either the catch is not making full contact to send this closed signal to the BDC or the switch itself has failed.
Did you replace the catch on the bonnet side or the engine side?
Discussion Starter #3
Thanks, I replaced both the catch because I had a little accident and one was broken and the other bent. But I got the replacement from bmx. It’s really annoying hearing this all the time
1 - 3 of 3 Posts
