1 - 18 of 18 Posts
hi folks in the past two months my mini cooper s 15 plate has broken down for the third time today
i parked up after driving for about half an hour popped in to my doctors came back out tryed to restart nothing happened tryed again and then noticed
smoke coming from the bonnet
opened bonnet all you could smell was a burnt smell no flames by the way
came up starter ignition problem on the main screen
phoned breakdown service and its away to the garage again third time ive had a starter problem really at my wits end i just want my mini fixed :crying:
That's a pity.
If it's the third time they have changed the starter motor, that would suggest something not right with the ring gear, with which the starter meshes when starting, or something else other than the starter motor itself.
Use of the stop/start technology shouldn't really cause a burnt out motor, unless the motor design is not quite up to it.
Keep us informed.
First time was a new starter and aircon motor it cut out when i was driving and refused to restart starter ignition fault on display
Second time new ecu it cut out when at traffic lights and restarted but felt sluggish when driving there was no power no faults on display
This time it was after i was driving and parked and was driving fine before
It came up power steering fault then came starter ignition fault
this is the first time some things burned out
Getting loan car tomorrow
Has anyone had to have there car replaced
That stinks! I hope MINI does right by you in correcting this awful situation.
That is a perfect example of a car not fit for purpose.
There are fundamental problems with the car, too many faults in too many electrical/electronic systems to be acceptable, especially at such a low mileage.
There are people on this forum who have rejected Minis and will know the procedure and may be able to help with advice.
Check your MINI warranty manual...
Your dealership has three attempts to correct safety related issues while your car is under warranty. If they fail, your warranty ensures a comparable MINI replacement.
I would suggest you contact MINI corporate (phone number is also in your user warranty manual) and speak with their able and helpful customer service to speed a prompt resolution.
Good luck to you!
I think one could be hard pressed to argue that a starter motor is a safety related issue, though... generally, the only things to rise to that level are items that will fling you into danger while in motion. Can always try it, tho
Good luck to you!
Not necessarily the case outside the USA. In the UK your contract is with the supplying dealer and nothing to do with MINI. There is also no stipulation about allowing 3 attempts to fix a fault.
I don't know about you but if a car cut out on me at a traffic light, drove in a sluggish manner, or managed to create smoke when parked...:eek:...I'd think safety issue. But then, I'm kind of quirky that way.:nerd:
Having seen a lot worse not rise to the level of a safety issue in the eyes of dealers and manufacturers, what you'd think and they'd think are often be miles apart...
Hence my suggestion to reach out to MINI corporate's customer service for a speedy resolution. However, I just learned "lemon laws" and ineffective successive fixes may not apply outside of the USA. Shocking!
Well, Mini Corporate would be the manufacturer I was referring to, but lemon laws don't even necessarily apply from state to state - each state has it's own set of laws and you have to work through those channels before you see if the Magnuson-Moss Warranty Act applies at the federal level... which can include everything from legal fees to mandated arbitration. It's really... something. Gives me a headache every time I think about it.
1 - 18 of 18 Posts
