Any ideas how to remove the handbrake grip itself?I did two weeks ago to install the NM Short Shift adaptor. It's not hard to do, just tedious, and a bit annoying in a Florida summer. Make sure your handbrake is pulled ALL the way up when it's time to remove it. Also, mind your seatbelts when you start putting things back together.
None - even after removing the center console, that handbrake grip was stuck on there with serious force.Any ideas how to remove the handbrake grip itself?
I found this but the link no longer works.Found this which tells me what I need, will leave here incase anyone else needs it:
http://www.nm-eng.com/media/attachments/361_NM.668846.pdf
