1 - 20 of 32 Posts
Hi all,
Looking to do the above but can’t find it in Bimmercode where I would expect to see it, even in expert mode.
Has anyone done this successfully and if so can you help guide me to the menu I need to be in please?
Thank you ?
2016 Clubman Cooper
There's a post on a Taiwanese forum Mobile01 by 'toodge' on how to code the cornering fog lights very recently.
I have done the coding but it didn't seem to have worked. I suspect it might be because I have retrofitted the auto lights switch (which gives me the 11 o'clock auto setting for headlights) rather than having it fitted from the factory.
The instructions basically are:
1. Make sure you have auto light(one with the 11 o'clock position)
2. Code the following:
Section 3062:
MAPPING_ABBIEGEL_L_OUTPUT: off→tfl_l(the option I saw in bimmercode was fl_l)
MAPPING_ABBIEGEL_R_OUTPUT: off→tfl_r
(although I've seen people from other bmw forum saying they use nsw_l and nsw_r)
Section 3066:
KL_ENABLE_LI :KL_Aus→KL_Ein
Section 3073:
KL_ENABLE_RE : KL_Aus→KL_Ein
C_BLC_ENA :F015_disable→F015_enable
C_CLC_ENA :F015_disable→F015_enable
3. Test - left fog turns on when you turn the wheel left and off when it goes back to straight.
Hi All
Let me help you.
If you use bimmercode to code, please use expert mode to change this value.
Section 3062:
MAPPING_ABBIEGEL_L_OUTPUT : 03
MAPPING_ABBIEGEL_R_OUTPUT : 04
I try this code. it can work on car with auto light switch.
Hi All
Let me help you.
Section 3062:
Is this under BDC module in bimmercode?
No. you need to code all lines.
Section 3062:
Section 3066:
Section 3073:
C_BLC_ENA :F015_disable→F015_enable (or 01 , please find this value on bimmercode)
2016 Clubman Cooper
Section 3062:
Section 3066:
Section 3073:
I don't think I saw a 03 and 04 option in Bimmercode expert mode when I did it. Is it a custom value?
Hi Sir
03 = nsw_l 04= nsw_r
I used esys to code this function. you can try on bimmercode.
Have you tried coding rear fog lights as brake light? I have F55 US model and I don't have switch on the panel for rear fog lights, only front fog light switch is there.
Hi Sir
My car is F54 clubman, the rear fog lights mapping is different with F55.
Maybe you can try to code this setting.
Section 3065
MAPPING_BREMSL_2_L_OUTPUT = nsl_l
MAPPING_BREMSL_2_R_OUTPUT = nsl_r
Section 3062:
Section 3066:
Section 3073:
I tried this on my F55 LCI with Auto light, does not work..
1 - 20 of 32 Posts
