21 - 32 of 32 Posts
Hi All
Let me help you.
If you use bimmercode to code, please use expert mode to change this value.
Section 3062:
MAPPING_ABBIEGEL_L_OUTPUT : 03
MAPPING_ABBIEGEL_R_OUTPUT : 04
I try this code. it can work on car with auto light switch.
Hello to all
As I told you via PM, it works at second try.. The error was because the engine wasn't running
Already tried and you can see on the picture.. No turn signal, wheel to left and left fog Light on 馃槉馃槉
Also notice that they fade in and fade out.. Amazing and beautiful
Thanks again!!!
Cheers
68932
Hello to all
Thanks again!!!
Cheers
Do you mean that the coding change has to be made while the engine is running? I use BimmerCode.
Yap
First I made with ignition on, engine OFF, and gave me a bimmer error.
Then I Dont know why with engine ON it worked and its working
PS: Edit - auto correct errors
Hmm that鈥檚 interesting. I code with the engine off and got no error, but it does not work. I wonder what鈥檚 the diff coding with the engine on...
Hi Sir
If you want to have cornering light, you have to check two thing.
1. You must have "Auto" light switch. and set on "Auto"
2. You should code correct on front fog light. Some car use TFL(03 04) as front fog light. the other use NSW(0B 0C).
Check this item BDC --> 3063 -->MAPPING_NEBELSCHW_L_OUTPUT ???? You should know your front fog light is what
Hi Sir
BDC 3062 or 3063?
No. you need to code all lines.
Section 3062:
Section 3066:
KL_ENABLE_LI :KL_Aus鈫扠L_Ein
KL_ENABLE_RE : KL_Aus鈫扠L_Ein
Section 3073:
C_BLC_ENA :F015_disable鈫扚015_enable (or 01 , please find this value on bimmercode)
C_CLC_ENA :F015_disable鈫扚015_enable
Hello my friend ! What else have you done to your mini ? Is there a way to activate the function of leaving home ? I don鈥檛 like that every time I lock my f56, the lights turn off
Section 3062:
Section 3066:
Section 3073:
Hello ! I did this and I they were working fine , but everytime I locked the car , seconds later the alarm gets activated , I used a backup to revert the coding and my mini is fine , do you know what happened ? I really want the cornering lights .
I have a f56 pepper 17鈥
21 - 32 of 32 Posts
