need to discuss a problem with my car , there is a problem – basically when you are driving gently maybe changing gear at around 2000- 2250rpm ( when the display tells you to) the car sometimes cuts the power a second or so after you have changed gear - 2nd to 3rd seems to be the worst. I noticed the problem straight away but I thought Iwould run the the car for a while to see if it improved. After nearly 3000 miles the problem seems to be getting slightly worse if anything !
It is particularly noticeable when you are going uphill as the loss of power slows you down more and results in an untidy jerk as you lose momentum then the power comes back .
It also does it in Mid and Sport modes but it is less likely to do it as you are automatically applying more throttle due to the different throttle mapping,
the problem only seems to occur when you are driving economically as you are using small throttle openings
Anyone else with a Cooper D noticed this ??
