1 - 4 of 4 Posts
First flown 600km ... :D
I am loving driving, fuel consumption of 5.9 L/100km, comfort, well above the previous generation, the gadgets are fabulous! >:D
Those who are waiting is worth it belive! ;)
Sadly now detected two problems ... :crying:
The first is already known ... the splashes of the windshield is I have never used the stained bonnet.
The second this seems to me worse, imagine I will at third in 2.500rpm and will reduce ... for second with your foot on the clutch the engine speeds up to 3,000 :eek: rpm already ordered a test drive in another Cooper D to know whether it makes same.
I was apprehensive about the response of the workshop since told me that the 1.5d engine is to be full of surprises ...
:eek::eek::eek:
I've started taking photos of my weeping washer nozzle... and then cleaning it as soon as I can. So far I believe
  • You don't have to use the washer for it to weep.
  • You get more weeping on longer journeys than shorter journeys.
  • It's heat related, but not sure if hot weather is required or engine heat is enough.
Your second problem... is that when you're changing down from third gear into second gear? I think the car is supposed to boost the revs in that situation... maybe someone else can confirm? Have a search for "rev matching"...
Yes the car has rev match when changing down so always gives the optimu
Revs.
Let me explain again
I'm going into third gear
Load on the clutch and the rotation instead of falling ... rising ... before the second gear being engaged ... :eek:
Sorry if I'm not making myself clear ... :nerd: :nerd: :nerd:
1 - 4 of 4 Posts
