@Fivetones would you have few more pictures of the rear end from different angles? I can’t decide on wheels so I’m going to do what you’ve done, put spacers on. I’m thinking of 12mm Lohen ones. I want to get rid of the recessed wheel look, especially the rear one. I can see on the above photo yours fill in the wheel arches nicely! Just wanted to see few more angles to help decide if I should go with 15mm on the rear as you did and if it’s worth to put 215s on. Did you keep the 205 tyres or went any wider? I think based on the below one can push it as far as 225 with the 7J. I probably wouldn’t want to do that though.
