We recently rented a F56 model Mini Cooper July 2015 registration, right hand drive manual with the 1.5 3 cylinder engine. We were enjoying driving it but on day 8 the following issue stopped us in our tracks.
In a town when looking for our place to stay, we did a couple of u-turns. On the 2nd u-turn (turning right) possibly on full lock (can't remember) I stopped to look on google maps as my GPS maps were hopelessly out of date. Then driving away failed as when letting the clutch up there was a sound of crunching gears. Thinking initially the gearbox had not engaged, put the clutch in, select another gear then back in first. Same thing, no forward progress. Tried the other gears to no avail. I rolled the car back and I believe now that this may have put the driveshaft in the hub far enough as we were able to drive off again (normally, no crunching of gears). Until we had to do a 3 point turn, then we didn't even hear gears crunching and you could let the clutch up completely while in gear and the car would not move.
The Mini was taken to the most local Mini garage where they found the drive shaft to be disconnected at the hub of the left (passenger side) wheel.
Now I do not believe that I did anything out of the ordinary. So my only explanation would be that the driveshaft could be too short so that at certain angles it is possible it could slip out of the hub?
Has anyone else heard/seen anything like this? The car was registered in July 2015 but would have been on a boat for a few months to the other side of the world. It had about 15,000 km on the odometer.
Ron
Ron
