1 - 4 of 4 Posts
I am working to enable rear fog lights on a 2021 F56 Cooper. This has been covered in the past elsewhere in the forum. I have replaced the panel light switch with the version having a rear fog light button (step 1). The next step is to add the rear fog light option (5AA) to the VO. Up to now I have only used Bimmercode to alter coding. It would appear that that app does not have the ability to change the VO. Is that right? If so, do I have to jump to E-SYS to do this? Or is there a different preferred coding app?
Discussion Starter · #2 ·
For those interested in this subject, I got the solution from the miniF56 forum: it can be done through Bimmercode without needing access to the VO. Here is the list of coding changes needed:
Body Controller>Expert Mode>
LCEmaster changes
> NSL_Verbaut to Verbaut
LCELampMapping3 changes
> Mapping_Nebelschlussl_L_ouput to nsl_l
> Mapping_Nebelschlussl_L_Function to nebelschlusslicht
> Mapping_Nebelschlussl_R_output to nsl_r
> Mapping_Nebelschlussl_R_Function to nebelschlusslicht
All done now, and I have working rear fog lights. Marvelous.
LCEmaster changes
we are talking when we update fro the rear bumper that's comes with only one rear fog light on the button?
2020 Mini Cooper HardTop S
MAy I ask where you got the switch from ? Most places show discontinued.
1 - 4 of 4 Posts
