1 - 8 of 8 Posts
You should be able to use a rubber mallot to tap the trims off. Once loose you should be able to pull them off.
Have you thought about refurbishing them with some wire wool and chrome polish? Perhaps just paint them black with high temp paint?
I'm looking to do the same. Could you please post (or PM me) the one you bought?
Thanks!
Here it is:
https://www.aliexpress.com/snapshot/8386045995.html?orderId=80057070081217&productId=32531768214
You have to choose the 57mm size.
As the exhaust tube is 55mm, you will have to add a piece of another tube between the tip and the exhaust.
The price is for one tip.
I bought it during a "black friday" so there was a 50% discount !!!
So it's worth to check.
Quality is good, and, for me, the look is fine ;)
Hi guys,
Sorry...Just a question.
Are the original end tips welded? Screw?
The inner diameter of the final part of the original exhaust on a JCW is also 63mm/2,5" tube? or 57mm?
I want at least change my end tips on original JCW exhaust.
My 06/2019 JCW with GPF won´t allow me the th change change for a full JCW pro exhaust... (dealership warranty)
So need help for cosmetic purpose only on my JCW.
Thanks.
1 - 8 of 8 Posts
