hi,
I have replaced front and rear pads and discs also front calipers. Tried to bleed the brake system according to newtis, 1.7bar pressure on the fluid cap, rear right left front right left bleeding. Brakes are slowing the car down, but the braking starts from after 2/3 of the pedal travel, before that there is little to no braking force. If I try to pump the brake while the car is off, pedal gets hard after ~2 presses and stays hard.
I have no clue how differently I should have done the bleeding.
Thanks for your advise!
