1 - 16 of 16 Posts
Hi, new here.
So, as the title states, I'm retrofitting a space saver on our 2016 cooper.
I've bought all the items on the attached parts diagram.
Now all I need to know is how to fit them.
Mini dealers haven't been much help with instructions
Can anyone help who has maybe done it already?
68381
diagram.
A guide from earlier models which might help?
Discussion Starter #4
Had already seen that one.
Seem to be far fewer parts to the F56 kit.
I bought the kit second hand complete along with the space saver wheel and tyre.
I'll be fitting it in a couple of weeks time to my 2016 F57 Convertible.
It looks straight forward enough.
Discussion Starter #6
Did you get any extra parts than what's shown in the diagram above?
I know the kit for the previous model had a spring clip in the boot that the holder fixed into.
Following, as I've been thinking about adding the spare to my 2019 F57 for some time. MINI eliminated the spare from the F55/56/57 in the U.S. for the 2019 model year. No clue where/how to install part #3 in the diagram above.
Discussion Starter #11
Further to this, make sure the spare wheel is the 15" fitted with a 115/70/15 tyre.
Anything bigger won't fit inside the housing.
I tried a 115/70/16 and it was just too big.
Discussion Starter #12
I've not done ours yet but part 3 looks like it bolts to the underside of the chassis to stop the main housing pulling up too far.
It all looks pretty straightforward 馃憤
How does this mount? On my 2019 F56 I have a huge muffler with the dual tips where I would think the spare would go. I don鈥檛 like the run flats.
Discussion Starter #14
If you have a cooper s with the twin exhaust then you can't fit a space saver.
Hi, new here.
Thanks View attachment 68381 diagram.
you will also need the wheel wrench from the mini tool kit as you use this to lower and raise the wheel on the car.
The wheel fits in the tray (1) and the polystyrene tray (4) fits inside the wheel, slide the tray under the car and take the mini wrench (thin end) and feed through the hole in the boot and screw onto the tray. Pull up the tray up as far as it will go and twist the wrench slightly clockwise so the tray holds. unscrew the wrench, put the plate (2) on and them put nut (5) and tighten up
Looking forward to learning what you find.
1 - 16 of 16 Posts
