1 - 2 of 2 Posts
Hi, I currently bought a damaged mini off a salvage auction. It didn’t have the passenger door on it as it was damaged and removed. The car has the mini yours package so it has the door LED Lights. Does anyone have the part number for the door wiring that has the correct connections that are needed? As this needs to be replaced and was on the car from factory. Thanks
Hood Automotive lighting Automotive design Car Vehicle
Hi, I currently bought a damaged mini off a salvage auction. It didn’t have the passenger door on it as it was damaged and removed. The car has the mini yours package so it has the door LED Lights. Does anyone have the part number for the door wiring that has the correct connections that are needed? As this needs to be replaced and was on the car from factory. Thanks View attachment 81525
what year is the car wiring is different as the led modules are different on older vs newer F56, if you have the vin i can get you the correct harness part number
1 - 2 of 2 Posts
