My info is intake air temps of 160F+ can cause problems.
I have driven at least one car in 116F ambient temperature with an intake air temperature of 135F (and a coolant temperature of 226F) with no ill effects. Have driven other cars in even hotter ambient temperature: 119F is my "record". But I didn't data log them during this time.
No telemetry from my MINIs but with my Porsche Turbo intake air temperature underway was 10F over ambient. The air to air charger coolers were quite effective at removing the heat caused by the compressing the air.
With my Dodge Challenger Scat Pack with Performance Pages which I had set up to display intake air temperature the Scat Pack -- naturally aspirated -- intake air temperature from a cold start and with minimal stop light time the intake air temperature would run about 5F over ambient. With "lots" of stop and go, or with some heat soak it could be 20F, 30F or more higher. But once moving at some speed with less time stopped and less time idling the intake air temperature would come right back down again.
A bit higher intake air temperature ain't necessarily bad in town, especially from a start. Hotter air means better fuel atomization, better combustion, better throttle response, better fuel economy, less engine deposits. And once under way while the intake air temperature falls the air through the intake is flowing faster and this helps atomize the fuel. So... win win.
