1 - 6 of 6 Posts
Hi
2 things i could do with some pointers on:
1. Fitted new fibre optic cable and bonnet actuators but still getting dash error. Does this need to be engineer reset? Can't find it on my OBD
2. Drivetrain error. Any ideas what this could be as again nothing comes up on the OBD reader.
Discussion Starter #3
Thanks for the reply, have checked there a few times but not only is it very sparse on this subject, it seems like the site has been taken down which is a real pain given i use it quite a lot.
Here's a copy. Note the procedure. Regards.
Home / MINI F56 Cooper S Hatchback / Repair Manuals and Technical Data / 72 Body parts and accessories / 72 12 Gas generators, airbag modules (with steering wheel airbag 3234) /
41 00 ...Procedure for vehicles with active pedestrian protection after an accident
The active pedestrian protection system consists of the following components:
  • Satellites (control unit + sensor)
    • Sensors, inside, bumper panel, left/centre/right
    • ACSM control unit (Crash Safety Module)
  • Cables and connectors
  • Engine compartment lid hinges
    • Actuator
In case of a frontal crash or side collision in the area of the bonnet and/or the A-pillars, check the following components:
  • Procedure
    • Read fault memory.
    • Disconnect the vehicle battery and observe the waiting period.
    • Rectify fault.
    • Reconnect the vehicle battery and observe the waiting period.
    • Delete the fault memory.
    • Switch off ignition and wait at least 2 minutes (no consumers, such as such as e.g. interior light, radio, etc., may be switched on during this period).
    • Switch the ignition on.
    • Read fault memory and rectify faults if necessary.
  • Procedure
    • Check cables and connectors for damage, replace if necessary.
Procedure with activation of active pedestrian protection:
Model Repair kit available
F15, F16 No
F20, F21, F22, F23, F32, F33, F34, F36, F80, F82, F83, F87 Yes
F55, F56, F57, F60 No
F45, F46, F48, F49, F39 No
Procedure without activation of active pedestrian protection:
Hi, unfortunately I am a complete amateur when it comes to this. I am able to follow a guide however. Just a couple of questions please if anyone can help. Firstly what software do i need for this? And where can I get it?
Secondly if you have a small head on collision as I have, does the cables burn out hence need replacing?
How do i know if my bonnet hinges/actuators need replacing?
Also has anybody been able to do this and if so are you close to Oxford as could really do with some help, will obviously cover your time.
Thanks guys
1 - 6 of 6 Posts
