With the help of a forum member 'bheights' who posted a guide/pic of central jacking points, i bit the bullet and tried it out - and it actually worked with no damage :laugh:
I jacked up the rear of the car first using my trolley jack and a soft piece of wood with a hole in it so the bolt head sat in, jacked up the car and placed floor jacks under the standard jacking points.
Then placed the trolley jack under the front central jack point with another piece of soft wood with a hole and jacked up the front and placed trolley jacks under the front standard jack points and it worked with nothing bent or damaged. May seem a little crude but i'm happy that this is an effective system to use if you want to do a tyre rotation yourself.
Also make life much easier for oil changes etc etc.
While I was at it, also did a brake pad inspection. After 9000km, I had between 9mm and 10mm of pad left. The pad is shaped from so when you're down to minimum depth, you can visually see that the surface area of the pad increases until your about 3mm of pad left.
with this, I have about 6-7mm of useful pad life left. not sure what the full thickness is (new pad) so this will tell me how much life i will have left in the pads before changing is required.
