Hello, It’s been about a month since my friend Nick and I installed Forge's intake hard pipe. Here’s an update and quick product review.
Purchased From:
: Way Motor Works, they had it in-stock and on sale at the time.
- https://www.waymotorworks.com/forge-...-f57-mini.html
Product Quality:
: Excellent
I understand why this product is normally not in-stock or backordered.
Removal and Installation:
: Forge’s instructions were straightforward and easy to follow.
The only difficult part was removing the OEM pipe in one piece without removal of the NM Engineering strut brace.
- We found it was easier to separate the OEM part by removing the one time use clamp then pulling the pipe out from the left side of the engine bay.
For the installation we removed three out of the four bolts on the NM Engineering brace and tilting it upwards.
- The fourth bolt would not come out and did not want to take a chance with stripping it.
Nick is going to post a video to his YouTube channel “The MINI Vlog” in more detail about the installation process. I will update this thread with the link once it’s up. Also he's a member of this forum!
- https://m.youtube.com/c/TheMINIVlog
Review:
: I’ve done about three hundred miles since installation. I can say that throttle response feels quicker and smoother especially in Sport mode. Inside the cabin you can hear the engine/turbo a little more but, I did not purchase this product for noise.
- I have Active Sound Design disabled via BimmerCode and the OEM engine air filter installed
: I love how this product cleans up the rear of the engine bay and it doesn’t scream aftermarket other than the silicon hose with their name on it
: Only downside is the silicone hose is thicker and with the strut brace installed you cannot easily change the engine air filter without removing the entire air filter assembly.
- It’s not a dealbreaker for me but just wanted to mention it in case any forum members had that question
: I haven’t really noticed the pipe getting hot but it does get warm. I feel and could be wrong but the plastic pipe felt hotter at times.
Gas Mileage:
: Before, 25-28mpg. I have the NM Engineering power module installed and set to low. Mixed driving conditions (street/highway and in Sport mode)
: After, 33.3mpg on the last drive which included heavy stop and go traffic on the highway in Sport mode and same low setting for the power module.
Overall I’m very happy with this product and it’s quality. Sure the installation could have been simpler by removing the heat shield, wipers and cowlings but we did not want to go down that rabbit hole.
Motor On
, Rich
Purchased From:
Product Quality:
: Excellent
Review:
Gas Mileage:
Motor On
