Ok think I have it sorted! You have to have bluetooth on the mobile, paired with the car to enable Minimalism and then access to the goldfish bowl! They don't make it easy - unless I'm stupid!!The only ref to goldfish that I'm aware of is that the front end of the car ( especially in VO ) is supposed to resemble a goldfish ?!
You've found NemoThe only ref to goldfish that I'm aware of is that the front end of the car ( especially in VO ) is supposed to resemble a goldfish ?!
Some would say that the clowns are those behind the wheel !!Nemo was a clownfish though![]()
For some reason it wasn't showing up until I connected and chose Minimalism but it's there now without being on bluetooth so will try it out tomorrow am when I go to the gym.You can also get the fish without the phone... you need to be in green mode, then it's under MINIMALISM > Minimalism Analyser (pretty sure).
It shows you that you accelerate to fast shift to fast and to close your Windows by showing you the vents in the cars with a green arrow graphic. Basically it's like having your mom next to you telling you to slow down and put up the windows. HahahahahaEr what does Minimalism do ?
