Ok, since my 9,000 lb auto lift appears to be too large to accommodate the really odd dimensions of the F56, I spent some time today figgeting with multiple locations of the lift arms to position the arms to line up with the MINI jacking points....it took forever! The F56 is very wide and the wheelbase (& thus the jack points) are "short"....tight spread for my lift jack points!
So, I marked the points on the arms of the lift to be able to lift the car by placing extra rubber pads on the arms. I want to compare with others who might have measured the 4 jack point positions: I measured 44" front to rear and 57" side to side. This is based on lining the car up exactly in the center of the lift with center to center tire span of 59"! Stock 205/40/18's on cup spoke wheels.
I marked the lift positions on all 4 lift arms along with the position on the floor, assuming I can get the car exactly centered when I drive it into the bay.
In theory this should work but it's not a one person job as I will need assistance lining up the car perfectly....never had this problem on "any other car"!
Again, my question is can anyone confirm the dimensions of the jacking points? Again, I got 44" long by 57" wide....only on a MINI! ;-)
Any other experiences also welcome for those of you with an automotive lift.
Thanks,
John
