Hey everybody. I recently purchased a 17 s 2door and am already having issues! I brought the car home with me on Sunday and everything was fine through Monday. Tuesday morning when trying to start the car I got a starter/ignition failure message on the display screen. I tried again to start the car a few times and this it finally turned on. Then later at night the same issue happened. This morning once again a starter/ignition issue and no matter how many times I tried it would not start. I called up the dealer and they told me they have never seen this before and to bring it into service!
There is a sensor on one of the battery terminals, it will throw a fault if a slight drop in voltage, it could be giving false readings causing the issue?
It says "call for roadside assistance." Mini will send out a flatbed tow truck
so that the vehicle will be towed to the nearest dealership for repair. All at n/c...under warranty.
weak battery. Mini fussy: yes as stated, sandpaper/rotary tool battery terminals (just one side ok) and maybe other grounds (use a multimeter to measure voltage dropn under 1500rpm+ load or even amps for slight weak wiring. Sounds implausible but cleaning alternator ground that already looked clean and 2 sides of battery terminals resolved my same issue.. dealers must love this that appears serious but is a minor easy fix.
Related Threads
Mini Cooper Forum
190.2K posts
33.2K members
Since 2013
You’re looking at the best place to talk about the Mini Cooper with other owners of the Mini F56 to discuss mods, problems and share tuning tips!
