I decided that for now I'm going to opt for an "OEM+" motif for my JCW. Part of that decision was centered around the fact that the new JCW Pro coilover offering is in fact built by KW, yet still comes with a MINIUSA warranty that spans the new car warranty. Motor City MINI gave me a lovely package price with the coilovers when buying the JCW, so it was an easy decision. Keep in mind the JCW is my daily driver, and I have my turbo Miata built up as the hardcore Hoosier-shod track car, so a dollop of comfort with sporting intentions are the theme here.
A little more unpacking shows the foam-wrapped rear springs, thread-locker compound, "Attention: John Cooper Works sport suspension installed" sticker (LOL), and front struts, the expanding foam keeping everything night and snug. JCW Pro coilovers unboxing by Ryephile, on Flickr
Here's an up-close of the stainless steel front strut, the stickers indicate "Left" and "Right" sides, and the "made by KW" clearly marked. JCW Pro coilovers unboxing by Ryephile, on Flickr
Here are the dampers and springs all together on the bench. The rear bumpstops have new dust boots snapped into them. I presume the fronts will re-use the original dust boot bellows JCW Pro coilovers unboxing by Ryephile, on Flickr
The rear springs, rear height adjusters with very nice rubber noise isolators, thread locker, wrench, and sticker. Where should the sticker go? :confused5: JCW Pro coilovers unboxing by Ryephile, on Flickr
Close up of the rear height adjuster. It's nicely anodized aluminum, likely right off the shelf at KW but anodized black instead of purple. The rubber isolator is actually a very OEM looking 2-piece design that plugs into the coil spring end. JCW Pro coilovers unboxing by Ryephile, on Flickr
In all it's a very nice looking kit. It's clear it's had an OEM touch over the normal KW offerings, which is a big plus. I'll post more information on the stroke and bumpstops when I remove the stock bits to have a solid comparison.
I swapped my front and rear wheels and it almost does not pull, it's minimal.
I have to measure the position of the ring under the spring (see photo). Right I have 31 mm and left 35 mm yet when I measure the height of the body at the level of the wing I have no difference.
Do you think I have to change my settings so that both springs are at the same height?
Ok, so i bought these and installed the rears perfectly fine but one of the front spring perchs is stripped. Does anyone know if i can just order a KW spring perch to replace it? I can't seem to find a mini part number for it, and since it is made by KW I am assuming that their parts should work on it right?
This has been a super helpful thread. My set arrive next week. Not looking for a 'slammed' look, just better damping and body control. I will post pics for those interested.
