1 - 6 of 6 Posts
(First post) So hello all
I’ve been reading all the threads on Bluetooth failure all over the net and have a question I can’t see an answer for ??
I know the control module is in the rear wing, so is it possible to wire a switch for activation rather than using Bluetooth ?
Discussion Starter #2
Found what I needed
The Bluetooth remote works just fine. If it doesn’t, then it’s likely a control module issue and should be sorted under warranty.
To be honest, don't be shy and just swap the battery. I was going nuts, hating the controller, thinking of going to the dealer then....brainwave...open it up, replace battery. BAM, works perfect again.
Just pay a pack of CR232 batteries (I think) from IKEA and you're golden.
Discussion Starter #6
I’ve changed the battery tried moving the controller and turning off all devices but it is still intermittent. Sometimes 0n for 2 minutes sometimes 5 before it switches itself off !!
1 - 6 of 6 Posts
