1 - 20 of 25 Posts
Has anyone code JCW start animation. If yes please share the steps
I don't think there is a jcw startup animation.
You can find this in headunit then expert mode, there you will find the animations.
Startup animations don't work allways, only by rebooting hu, it does not work like bmw.
Change Animation
In HU_NBT/HU_NBT2:
STARTUP_EMBLEM
These are the options for touchscreen units but the non-touch displays are similar:
variant_00=BMW Connected Services;
variant_01= BMW ///M;
variant_02=Alpina;
variant_03=BMW i;
variant_04=MINI;
variant_05=BMW Connected Drive;
variant_06=BMW Connected Drive Gold;
variant_07=John Cooper Works;
variant_08=New MINI Logo;
variant_09=BMW ///M Alt (less animation)
Discussion Starter #5
Change Animation
In HU_NBT/HU_NBT2:
STARTUP_EMBLEM
variant_02=Alpina;
variant_03=BMW i;
variant_04=MINI;
Bimmercode?
Discussion Starter #9
So to make sure everything is right
For cars without touch screen
I go head unit then expert mode then EXBOX then I select on ( STARTUP_EMBLEM ) then variant_07?
Discussion Starter #11
If this is the correct way unfortunately it didn't work
Discussion Starter #14
U should fully turn off the car completely and wait for few minutes to turn it on should work
Thats what i did
Actually what ever number you select in the expert mode it will change in the normal mode ( start animation) for example number 7 i found out it changed to bmw something.
So what ever from 0 to 9 in the expert its the same in the normal mode under start animation.
Example i chose 8 which you say its new mini logo i got bmw animation.
I believe JCW animation doesn't exist or i did something wrong.
Change Animation
In HU_NBT/HU_NBT2:
STARTUP_EMBLEM
variant_02=Alpina;
variant_03=BMW i;
variant_04=MINI;
variant_10=MINI Electric
variant_11=MINI GP
I wonder do you guys have something that I don't have hahaha I only have from 0to9 and 7 was bmw logo not jcw
I told you so, and only works when powered off complete and then you will see start up logo
Did you when you select one of the 9,return from expert mode and then right corner up in your screen used the code button?
Discussion Starter #19 (Edited)
Yes logo has been changed but not to JCW.
I have selected all 9 and JCW logo doesn't exist.
1 - 20 of 25 Posts
