1 - 8 of 8 Posts
Hi!
I have read that LED headlights retrofit is not possible (or too complicated) for the F56. But I quite never understood why.
I have a Cooper F56 and after a minor accident both halogen headlights, standard on mine, must be changed. I was thinking then to get a pair of LED headlights.
What else would I need? Would that be possible, even if I have to change wiring and other components?
Last question, if changing the headlights is not possible can I at least put LED daytime lights and add front fog lights (I have found a very cheap pair of led front fog lights on eBay)?
Thank you so much!
Hi!
Thank you so much!
There's more to it than just changing wiring. If you're going to do it, then don't half ass it. Just sticking LED bulbs in mirror reflective housing is scattering the light thus making them ineffective and blinding to on-coming drivers. You need proper projectors.
Thank you swearingino! Of course I would go with proper original projectors but they are not the difficult part.
I have easily found the part number of LED projectors, the problem is all the rest I would need :) has someone got an idea of which part numbers I would need (wiring, ECU?,...) to complete the work?
There's also an official MINI LED DRL/fog light retrofit for F5x cars without LED headlights, similar to the kit they have for the 2nd gen MINIs:
There's a LED 'halo' that acts as DRL and they reduce to a crescent when the headlights turn on or when the fogs are activated. IMO, I think they are a little cooler than the stock LED fogs that come with the LED headlights.
Part #s and diagram here:
http://www.realoem.com/bmw/enUS/showparts?id=XP73-USA-09-2015-F56-Mini-Cooper_S&diagId=63_1691
Reactions: brandonbardsley
1 - 8 of 8 Posts
