Hi folks,
Thanks for the replies.
Having had a chance to play I have discovered :-
If you have the lights set on Auto the side lights, as in top half of fog lights don't light up.they only come on if you press the Fog light button....but of course, so do the fog lights.
If the lights are on the off position and you go to side light position the side light come on,as in top part only of the fog lights, but the daylight running lights don't???? Only when you turn the dip beam on then the daylight running lights come on.
The mini guru in the dealer is looking into whether the daylight running lights can be on with the side lights, as that would look cool ?
Anyone know if that can be done?
Cheers
