Hello!
I replaced the halogen bulb with an Osram LED. It is straightforward just twist the socket take out the bulb with the housing and replace.
I am annoyed by the message that pops up all the time. I purchased a osram cambus control in order to get rid of the message. But now I am facing different problem..as you know, you are supposed to clip the resistor on + and 0 that goes to the socket where led bulb is installed. But there is no wires, just twisting socket 😂
I believe that it can be done if you know what wire goes to the reverse light, do anyone knows where can I find that wire?
Osram Cambus Control
