Thanks! Me - stupid or wot?Push the "control knob" to the right and there you should have quick access to switch either or both off, if not keep pushing it to the right and the screen you need will appear. It's designed to be quick access
Not if you don't have sensors!!>And goes red if you're about to reverse into something![]()
I guess the LED ring is ALWAYS ON, as per the AMBIENT LIGHTING? No OFF switch?It shows the volume level as you adjust it... and it shows distance until the next satnav instruction, but it doesn't do that until you're quite close.
Somewhere in the settings is a screen of checkboxes so you can select which events it responds to.
Yes, and easily done.It can be completely turned off as far as i know
Is that by turning off ALL events and STANDARD? No quick way as per central display via selector knob?The "standard" option is the colour of the ring (or off, or rev counter) when no other event is occurring.
The red and amber stay where they are. What does change as how much from the left is illuminated in white.Hi. When I set the central display to act as a rev indicator it looks like it's frozen with a red/Amber glow at the far right of the led ring. Is this a fault or am I not doing something I should. I was under the impression the lights acted as a Rev counter as the revs rise. Thanks for any info ?
