I was wondering if anybody knows the dimensions of the F55 cargo bed with the rear seats folded down.
I'm wondering how my surfboard will fit. With my old R50 I could always fit my surfboard in between the driver and passenger seat sort of standing up in the center of the car and barely close the hatch. I know the F55 is going to be a bit longer than the standard Minis and even those are longer than my R50, so I wonder if I could fit my board in more easily now.
I'm wondering what the straight line distance is from the boot to the back of the front seat is, and what the distance from the boot to the dashboard is. Also it would be interesting to know the diagonal distance in the cargo bay as well.
Here is the info from Mini USA but it is in ft/3. :( If you have anymore questions about centimeters I can translate it for you
http://www.miniusa.com/content/miniusa/en/model/hardtop-4-door/specs.html
Trunk Volume 13.1 ft. 3 13.1 ft. 3
Cargo Volume 40.7 ft. 3 40.7 ft. 3
got this of the German Mini Forum in cm the last line translates into seats folded down of 137 cm deep/lomg the with is 100cm from left to right
Breite des Kofferraums beträgt 100cm
- die große Seite der umklappbaren Rückenlehne beträgt 60cm
- die kurze Seite 40cm
- Höhe doppelter Boden 13cm + 2cm Bodenstärke, also gewinnt man ohne den Boden 15cm an Höhe
- vom Kofferraumboden bis unter die Abdeckung 42cm (ohne doppelten Boden 57cm)
- vom Kofferraumboden bis unters Dach 70cm (ohne doppelten Boden 87)
- Tiefe Kofferraum 56cm
- Tiefe mit umgeklappter Rückenlehne 137cm
Trunk Volume13.1 ft. 313.1 ft. 3
Cargo Volume40.7 ft. 340.7 ft. 3
Thanks for looking this up! :) The first part doesn't help me too much because I want to know how long of an object I can fit and the volume isn't that useful because different length width height combinations can make up the same volume.
And I'm pretty sure that German info is for the f56 although I could be wrong.
Jax the 137 cm is for the F55. The F56 got 120cm look at the last line.
Abmessungen F56:
- Breite des Kofferraums beträgt 100cm
- die große Seite der umklappbaren Rückenlehne beträgt 60,5cm
- die kurze Seite 39,5cm
- Höhe doppelter Boden 14cm + 1,5cm Bodenstärke, also gewinnt man ohne den Boden 15,5cm an Höhe
- vom Kofferraumboden bis unter die Abdeckung 41cm (ohne doppelten Boden 56,5cm)
- vom Kofferraumboden bis unters Dach 70cm (ohne doppelten Boden 85,5)
- Tiefe Kofferraum 42cm
- Tiefe mit umgeklappter Rückenlehne 120cm
Abmessungen F55:
Abmessungen F56:
Abmessungen F55:
Oh I see! :). Well I guess that's my answer then. Thank you! :)
