1 - 6 of 6 Posts
Dear everyone,
I'm looking for a set of OEM LED DRLs for halogen headlight-equipped Minis, part number 63122361243. They have seemingly been taken out of production, so would appreciate any leads. Second hand is OK as well.
You could do what I'm doing, and just get the LED drl/fog units off a production model.
There are different part numbers. I have these to fit:
Font Circle Auto part Brand Rim
I believe these are the parts I have, but I could be wrong.
You can buy from www.lllparts.co.uk or www.hubauer-shop.de if you like. Try the retrofit kit part number too.
I think these are the parts I have.
Rectangle Font Parallel Screenshot Number
Thanks for the tip. Have you already made it work, and if yes, how?
Not yet.
Halogen DRLs have 6 wires, 3 supply and 3 ground.
The LEDs have 4 (you MUST get the ones for cars with halogen headlights, otherwise the DRL is in the headlight), 3 power and 1 ground.
What I plan to do is simply tape up the 2 smallest ground wires and splice the remaining 4 wires onto a plug that will fit the new unit (my used ones came with the pigtails attached ;) )
I don't think any wiring is changed at the BDC, but if it is I will repin accordingly.
Then it should just be a matter of coding out "520 Fog Lights" and coding in "5A1 LED fog lights" in the FA/VO.
Not yet.
Hey, did you get this installed and working? Interested to hear?
1 - 6 of 6 Posts
