1 - 2 of 2 Posts
Good morning.
I have a 2014 Mini Cooper D and I would like to know if you can help me with the following problem:
Sometimes the car has a metallic noise that comes from the exhaust area. The noise only appears in acceleration and at 1600rpm. Above that rotation, it doesn't.
When the noise appears, I also feel that the car has something stuck to accelerate, as if something is stopping the car. Before recording the video with the car stopped, I thought the noise came from the brakes.
I share the video below:
Has anyone had a similar problem with your car?
I apologize in advance if this matter has been discussed previously.
Thanks.
Can’t see your YouTube video for some reason, but if it’s only at a certain RPM, then it might be a loose heat shield that’s come undone over time.
If it was something mechanical I would imagine it would only get worse the more you revved.
1 - 2 of 2 Posts
