Need some help, hopefully someone here has had an issue like this.
I’ve bought a 8.8” Screen for my mini. Came with a 6.5” originally. i’ve also got a droidUK MMi box installed.
I installed the new screen today and coded (bimmercode) like the forums etc advise. “Variante and Size resolution”
Issue is only the carplay box works. the mini system didn’t work at all. we then reverted the settings to what they were originally and the i drive worked but only 2/3 of the screen. (the head unit was in full screen mode but only showing 2/3 of it. Around 5 minutes later of the car being off and closed i got back in and the screen turned black again with carplay working. Any advice?
I read somewhere that it sometimes you need to code it through e-sys as it can play up a bit
Also when i went onto bimmercode originally the setting that was on there was that 10.25 1280x800 not 6.5 800x600
Help me plz
Help me plz
