Depends to be honest if you love driving-the manual gives you more connection but you could have clutch wear issues and make sure the recall check on the big end bearings has been done-a few cars had the wrong ones fitted and the clutch went! There was a recall or quality enhancement at some point but they'll know the years affected. The auto has of course no clutch wear issues, and very rarely causes issues-just one or two on here as far as I know so both should if well looked after , be reliable. Make sure the b pillar paint wear issue isn't bad or film is applied-check the metal at the door seal below drivers and passenger shoulders!
