1 - 7 of 7 Posts
Hi All,
Newbie question here...
In my previous car I had regular trips to the garage to check and pump the tyres but they now charge 50p per go to use the air.
I was looking at buying a compressor for use at home but then noticed there's a small one in the boot...
Can I use the Mini Mobility Pack Compressor in the boot to check and pump up the tyres on a regular basis?
Anyone else tried this?
Neil
i can 't imagine it is good enough quality to use on a regular basis but you could try; i simply bought a good stand mounted bike pump; it's great and easy wiht a built in guage!
Sounds good then.personally the time taken to get it plugged in and staffing with words means I do it manually. Checked every other week each tyre rarely needs more than a couple of pumps!
This reminds me as not done mine for sometime :|
Also annoyed as no plug in the boot anymore!
It's meant to inflate your tyre so I guess it will be usable for regular checks and pump some air in the tyre when it's needed.
I have a big air compressor in my garage and I use it also to dry my wheels, brakes and between the panels of the car after I wash it. They hardly cost anything anymore if you don't need a professional one. I can recommend one for all kind of use.
1 - 7 of 7 Posts
