1 - 8 of 8 Posts
Battery losing power tracked back to the junction box anyone on here got a diargm for the junction box or any ideas altonor is fine it's been checked any ideas due to. Hand the car back
Cooper S Works 210
How old is the car? if it's still under warranty take it back for them to sort out, if you do anything yourself you could void the warranty.
Did you have the new battery coded to the car?
Discussion Starter #3
Hi was the same ah as the last one I had in it the car is a 2014 plate not under warranty as its second hand
Discussion Starter #5
I will see if that makes a difference where should I take it to get coded in
Mini will do it of course but a garage with the correct computer equipment; might need to ring round and see if you can find a mini specialist in your area?
Discussion Starter #7
Thanks there is one in Irvine hut wither they are open or not is the things an how much it will cost
Cooper S Works 210
Most garages charge around 1/2 hour labour for diagnostics, al least with coding no parts are needed.
I know Bimmercode wont code batteries (but you can select different types?), maybe someone with Bimmerlink or another ap could do it if you know anyone local?
1 - 8 of 8 Posts
