First place to check is the door and bonnet sensors/switches. It's common for these especially the bonnet switch to trigger the alarm.
Thanks I'll try that next, I've cleaned all the catches up today and thrown the fuse back in to make it live again. Will have to see if it wakes us and the street up at 3am again lol if I do try this next, do I just unplug and wait a bit before plugging back in, or just pull the wire completely, and which connection do I need to actually pull?Try disconnect/connect this headliner control unit.
UnplugThanks I'll try that next, I've cleaned all the catches up today and thrown the fuse back in to make it live again. Will have to see if it wakes us and the street up at 3am again lol if I do try this next, do I just unplug and wait a bit before plugging back in, or just pull the wire completely, and which connection do I need to actually pull?
Excellent thanks mate, I'll give that a go either tomorrow when I get back or on Thursday morning, as I said before it's an intermittent fault so it may behave tonight anyway and lay up tomorrow when the wife is out in it, or tomorrow night.Unplug
start/stop engine
then plug them back. Both connectors
How to remove overhead unitExcellent thanks mate, I'll give that a go either tomorrow when I get back or on Thursday morning, as I said before it's an intermittent fault so it may behave tonight anyway and lay up tomorrow when the wife is out in it, or tomorrow night.
Thanks I'll be trying that tomorrow morning, alarm lasted till 5am this morning before going off, fuse pulled again at moment! I'll give the neighbours a night off, try your idea and then see how it behaves on Thurs night. It only seems to go off early hours of night, do strange!
So I've removed the unit and unpluged, started and stopped then plugged in again and reinstalled the head unit. I'll leave it to see if the neighbours get some sleep tonight! I've changed the key fob batteries, but I'm thinking the main car battery may also need a change as its only showing 12.2 volts when at standstill with ignition off. I'll see if the alarm behaves tonight, but next step will be new main battery I think!
Are the lights flashing when you lock/unlock the car now?So I've removed the unit and unpluged, started and stopped then plugged in again and reinstalled the head unit. I'll leave it to see if the neighbours get some sleep tonight! I've changed the key fob batteries, but I'm thinking the main car battery may also need a change as its only showing 12.2 volts when at standstill with ignition off. I'll see if the alarm behaves tonight, but next step will be new main battery I think!
Yeah the indicator lights do.Are the lights flashing when you lock/unlock the car now?
fingers crossed thenYeah the indicator lights do.
I'll report back tomorrow!fingers crossed then![]()
Nail on the head! Thanks for the advice. I have checked the battery again today after it was sat for the night. As I said it was 12.2 yesterday after we had been out in it and it was sat at rest, I checked it was charging and got a good read of 14.8 whilst running, so it's definitely getting charged properly by the car. This morning it's only showing 12v so looks like it's definitely dying anyway. So I'll get that picked up today and tomorrow at some point. Then hopefully the Mrs will have a trouble free car, thanks again all and especially stuI'll report back tomorrow!
No alarm In the night so hoping that you have hit the
Well, after a change off battery in remote hey fob (just to be safe),, the help from Stu with the tip and a change of battery I. The car itself, it looks like we have a winner and the alarm problem has been resolved. Thanks for all the help
