Specs:
NM lowering springs
NM 22mm Rear Sway bar with NM rubber bushings and factory mounts set on full stiff setting (first hole)
So... after installing my new NM springs and sway bar, i have a super loud creaking coming from the rear of the car. I went back to my shop yesterday, took everything back apart in the rear, used all of the grease that came with the sway bars and the creaking seems worse now.
The creaks is most prevalent on accel\decel, not when going over bumps or speed bumps.
I have been super happy with the ride of the springs and the handling improvement but the sways are really bugging me. Has anyone else had this problem? Did you use a different grease or wrap with teflon? i have aftermarket sway bars on 2 bmws (e30 and mroady) and have never had any noise from them.
thanks for the assist everyone, i did a search first and didn't see any threads on this. I sent an email to Jerry as NM also.
Tony
NM lowering springs
Tony
