1 - 6 of 6 Posts
Checked the oil level today. Ran the electronic check, at the end showed a green vertical line with a black hohorizontal bar just slightly above an estemated third. Checked the manual for how much to add: " only add engine oil when the message is displayed in the instrument cluster".
Do i get a message to add oil or do i put some in now and how much is safe to add?
Never had it in my mini but my BMW had the same system, That told you when to add oil and only when it wanted a litre top up.
From the top of the bar to the bottom is a litre so if you wanted to add any before it asks its pretty easy to work out how much to put in.
Discussion Starter #3
Ok BigDave, thanks for the information.
You just need to remember to run the check oil level again after you have topped up or it won't register and will scream at you to top up again.
I'd definitely top up before it asks you to. I like mine on full!
1 - 6 of 6 Posts
