21 - 35 of 35 Posts
oke, i hope its clear, lets go further with coding....
your still in the BDC, go into expert mode and search for PfExternalMirrorMaster.
Then you will see a lot of stuff
asp memory verbaut tap on it and set AKTIVE go < back left upper corner and then code right upper corner.
All the rest I write you do the same....
asp nichtkomfortbeiklappen bei blinken AKTIVE
asp heizung verbaut AKTIVE
asp beiklappen AKTIVE
asp bordsteinautomatik AKTIVE
asp heizung verzoegern nach kl15 ein AKTIVE
asp beiklappen bei komfortschliessen AKTIVE
asp bordsteinautomatik delta 59 DIGITS
asp ausklappen nach komfortschliessen AKTIVE
asp aba aktiverung, with this function the mirrors follow in a curve so you can activate them or not
asp elektrochrome spiegelglas AKTIVE
When you have done this everything will work
heated mirrors will work if you have heated seats or old mirrors where heated.
folding inn on keyfob will work if you have comfort closing.
comfort closing ad the door outside will work (push a little longer then normal about 3 seconds
dimmable mirrors will work if you have dimmable interior mirror
the folding button will work on the driverside
when the button for mirror up/down/left/right is in the drivers position, the mirror will tilt in reverse
Hi. I’ve been trying to retro fit my mirrors this morning and now my electric windows won’t go down on the control unit. I am yet to code in my mirrors, but wouldn’t have thought that coding would effect the windows.
Toby
the rest of the coding parts a will post later
Thanks @guillermo013, I followed your instructions on the wiring and it works perfectly! I did the P313 VO coding on the BDC and I set the comfort closing mirrors in BimmerCode, now everything works.
Reactions: guillermo013
I just finished following Guillermo steps and worked fine. Mine is JCW pretty basic options, no hk audio, no confort open/close, etc.. but it worked fine =).
After locking and unlocking the car, the mirrors fold fine, the button too, reverse tilt. Used Vgate Wifi with bimmerapp to code on an iPhone.
Thank you @guillermo013 !!
I have a 2016 Cooper s. Was wondering if anybody knows the part numbers of the door switch and the electric mirrors.
Hello Bezlar,
Switch 61319354854
you need mirrors with the blue plug like in the picture 3pin, your car needs to have the 5 pin
like in the picture installed otherwise It will not work.
I have too look for mirror parts numbers, but you will need the electrochrome mirrors.
You can find them on Ebay.
Best regards,
Guillermo
Hello Bezlar,
Switch 61319354854
Best regards,
Guillermo
I ask for my F60 JCW but I think it is the same for the F56 ...
how do you understand or if someone confirms: my driver's side mirror is chromatic, what is the passenger's mirror, normal or chromatic ?
Thank you very much.
2014 F-56 Cooper
At the back off the mirrorglass you can see what kind of glass it is, there is a little sticker on it.
Chromatic glass has a little edge on the side. Photo is chromatic glass
69992
21 - 35 of 35 Posts
