Is there anyone having a problem with the PCV valve? Two F56 takes the towing this week with the same problem. Mini must change the valve cover, the PCV valve is integrate, after they found it cause some wetness in the engine's head. Mine goes under engine protection, flood the engine, clog the exhaust systems causing overheat and melting exhaust support. It took more than 2 days of research at my dealer to found the problem. The second one just went bad when starting and stall after that. Same problem, same body colour (black) same waiting time for the parts ( 2 weeks).
