1 - 10 of 10 Posts
I am planning on buying the JCW when it comes out and I will be heavily modifying it. The problem is I am able to get everything I need except for a California legal catalytic converter. Does anybody have any good suggestions?:D
· Premium Member
I have some questions:
1-CARB has some pretty strict laws when it comes to changing out the Catalytic Converter, so how do you know that you need to change it out?
2-The JCW isn't even out yet so how are there parts available or are you just going by what's available for the F56 S?
:confused:
Discussion Starter · #6 · (Edited)
Cat
Ok, so I have found a 3" cat for general use. I want to modify the JCW because I want more hp but with stock JCW look and the suspension/brake upgrades. There are plenty of reasons. Basically my plan is to increase my entire exhaust system in place for a heavily upgraded turbo. I have been talking to a company that custom forges these turbos and they are expecting anywhere between 350-450 hp.
Link to CAT: http://www.jegs.com/i/Magnaflow/642/51659/10002/-1?parentProductId=2867855
I've seen way higher hp in way funkier fwd cars. Also, the clutch will be a stage 3 clutch and apparently the gearbox is supposed to be able to handle it. I will have two modes for driving; a low boost everyday mode and a high boost track day mode.
1 - 10 of 10 Posts
