If you leave your car standing outside after recent rain, wear a raincoat when you open the door!!! The same applies when you get out of the car after rain. Serious design fault in my view.
It's a feature of most modern gutterless cars regardless of make..........
Regards Bob
A DeWalt will solve the water dripping problems plug it in and watch the water go away never mind that you might look a bit silly vac the roof of your car in the parking lot.
Runs off of 12-volt and 18-volt DEWALT battery packs (not included) or 120-volt ac
Gore wet/dry filter traps 99.7% of drywall dust
Wet/dry filter eliminates change overs
Washable filter; tap or water rinse to clean
Heavy-duty rubber hose provides durability and flexibility; drain port on tank for easy emptying of liquids
Ditto. Luckily never had a problem (rain or snow). Maybe a product of the angle the car is at when parked? I'm parked on a slight incline, so rain and everything tends to go towards the boot of the car rather than down the sides.What am I missing guys, I live in rural Aberdeenshire, so I'm no stranger to rain, but I've never had a problem with this.
