Donna, buy some Biltstein,s and have the Dealer install them. You only can eat so many Cookies and drink Cappocinno,s while sitting around in the Mini Lounge.
Description
BILSTEIN B8 - Performance you can feel and use for your Mini Cooper! Although there are other brands of monotube gas shocks making an appearance in America’s pit areas, Bilstein technology is so far ahead and so different, that their performance cannot be equaled. Bilstein's gas charged monotube designs are far superior in quality, performance, and durability compared to the 'less-expensive' twin-tube designs (twintube technology is relatively unsophisticated and very low cost to produce).
Fits the following models:
2013+ F56 MINI Cooper and Cooper S Hardtop
2014+ F55 MINI Cooper and Cooper S Hardtop 4-Door
NOTE: Not compatible with the factory Adaptive Damper option.
Available in Heavy Duty or Sport versions. Each shock sold individually. Select accordingly.
Bilstein B8 Sport monotube shocks and struts deliver absolute mastery of the road surface for the performance-minded driver. Designed to push a car's suspension to its performance peak, these shocks are specifically suited for use with special lowering springs in combination with anti-sway bars or other suspension upgrades. (yellow paint, steel body)
Product benefits at a glance:
Shortened high-performance shock aborbers for virtually every lowering spring set and series production sport vehicles
Sports settings with high level of comfort
Marked improvement in safety and performance with additional spring changes (lowering)
BILSTEIN gas pressure technology
BILSTEIN mono-tube / Upside-Down technology, made in Germany
Road and track tested by BILSTEIN for fine tuning
