1 - 20 of 20 Posts
Hello I'm a new 2018 Mini Cooper Hardtop owner and I need some help with the lights I just installed.
Hopefully it's a BimmerCode fix? Any help is most appreciated!
72099
72100
2020 Mini Cooper Oxford edition. Starlight blue with black top, black mirror caps and black wheels.
Dang it..should have used grammerly. Want to make them work LIKE this...
72113
Just to clarify, you want them to look like this? this is how my car came from the factory, so wouldn't that be the default setting?.
Yes I want them like yours. But see from the 2nd pic, sorry those are actually my running lights/parking lights. The LED rings don't light up like yours. I'm almost thinking that I have to do the pin swap and coding I have found going from Halogen to UJ led lights?
View attachment 72113 Just to clarify, you want them to look like this? this is how my car came from the factory, so wouldn't that be the default setting?.
Hello did you were able to fix it?
I want to change mine to the LED also.
Hello, Yes I completed the job and they look and function great! Included a wire swap, wire tap, and coding but I figured it all out! I did document and recorded multiple videos. I'll gather it all up and post it here.
Also converted the halogen headlights to LED they look sick!
73058
73059
The wire swap is the same that people do for the Union Jack lights, right?
By the way, the car is amazing with the new lights, congratulations
Discussion Starter · #10 ·
Thanks!
I think the code is the same. It involves moving the 1 wire and sticking it into the 5th empty plug on a 6 pin plug. I am trying to find that thread. The coding is what you need to make the tail lights and break lights act independent of each other.
Discussion Starter · #11 ·
Okay here is all the info. I hope it helps. Let me know if you have any questions and I'll do my best to answer. Wrote out all the steps and the vid is goes along with it.
Of course Disclaimer: NOT RESPONSIBLE for YOUR CAR. I did this for my own purpose on my 2018 Mini Cooper 2 Door Hardtop.Posting this as a help, to anyone seeking the same results.
I searched for hours, and could not find anything about this light swap. Everything I found was for the union jack swaps. I hope it helps.
That being said shall we begin?!
Mini Light Swap Vid
NOTE: the LED flicker is the vid is do to frame rate. They are solid to the look at.
Step 1
Install lights
Pull the 6-pin wire harness
I had a 6-pin that was only using 5 wires.
Remove the purple clip
Pull the 1 wire and put in into the 5th port in the connector. It was not being used on my car
bimmercode the codes found in Step 1 Links below
This makes the tail lights and brake lights separate and independent from each other
Links to Step 1
Union Jack Taillights - North American Motoring
Links to Step 1 Pre-face lift
Step 2 (optional)
Replaced all Halogen bulbs with LED bulbs.
Personal preference, like the brightness and sharpness of LEDs.
Tried and tested a bunch of different types and styles.
Liked the lights below
LED Reverse Lights
https://amzn.to/31UXfGG
LED Brake Lights (need quantity of 2)
Amazon.com: SIRIUSLED KG Series 1156 1141 7506 Super Bright LED Bulb 2835 SMD High Lumen for car Back up Turn Signal Tail Brake Light Pack of 2 (Red): Automotive
LED Rear Blinker Lights (same as Brake Lights)
Step 3
I used a volt-meter to map out my rear lights
This is what I discovered for my lights (see diagram in vid)
6 pin number starting out from top to bottom with 5th not being used
1 = Brake Light Bottom
2 = Blinker
3 = Negative
4 = Reverse
5 = LED (new lights)
6 = Brake Light Top
Getting power to the bottom brake light via a wire tap from the top brake light.
I bought all the things I needed including the wire taps, connectors, crimping tools
I also bought a 6 pin connector with 6 wires off of ebay.
Pulled a wire from that to create my wire tap.
Links to all that below
Pulled a wire from a 6 pin connector I bought on ebay.
Put a wire tap connector on the end of that wire
Wire tapped the 1 wire on the car. Black and Yellow for me
Plugged the connector into the wire tap
and plugged the pin into the 6 pin wire harness
Bimmercode to tell the car these are all LED bulbs
GOOD TO GO!
Coding part 2
Bimmercode: 1. Rear Brake, 2. Rear Indicators, 3. Rear Adaptive Brake, 4. Tail Lights, ALL to LED, hot and cold monitoring to NON-Active
Mini 6 pin
Tail Light Wire Harness
11.8 in Harness Tail Light Wire Harness For Mini Cooper TailLight Socket 6-wire | eBay
Tools
Crimping Tool
https://amzn.to/3uur11c
Wire Taps
https://amzn.to/3uw1eWj
Wire Strippers
https://amzn.to/39OOnH6
Volt Meter
https://amzn.to/39MTebJ
Links to every other items I bought and used for the car
Torque Wrench
https://amzn.to/3muWEoM
Telescoping Lug (Breaker) Wrench
https://amzn.to/3dFNodq
Shine Armor
https://amzn.to/3mwaNC6
Quik Detailer
https://amzn.to/3mslVzG
Hybrid Ceramic Quik Clay Kit
https://amzn.to/2R62VLJ
Hybrid Ceramic Detailer
https://amzn.to/3t3iMJ9
Hybrid Ceramic Liquid Wax
https://amzn.to/3mtSRIa
Mini Front Parking Lights
https://ebay.us/GT6utc
Mini All Weather Floor Mats Front
https://ebay.us/gp3MU7
Mini All Weather Floor Mats Rear
https://ebay.us/YJUwQO
Mini Wheel Lock Set
https://ebay.us/jVSYtS
Discussion Starter · #12 ·
Sorry it took so long to gather and make sense of everything. Hope this is helpful and good luck!
You're welcome. Yeah it was and it took about a month because I didn't know how to do any of it! Had to wait on parts and tools.
Hello again!
I found a bargain and will buy this tail lights.
Just wondering do you know the exact things you needed to change in Bimmercode? Besides put all to LED and disable monitoring!
Discussion Starter · #16 ·
Hello again!
Hey now!
Yeah from up above link to step 1. You have to know if your car is pre-facelift or not. Mine was pre-facelift so the second link. Scroll down a bit and find the codes after the pics he has. I took a screenshot of the codes I did. Read around that link because if I remember correctly these codes tell the car that the parking and brake lights are different. Probably check out my vid too, because it was more fresh on my mind then! HAHA
BTW my lights still work and look amazing! Good Luck!
74465
Hey now!
Thank you!
Mini is from 10/2017 so it is pre-facelift also, I think.
Hello!
Just bought the new rear lights !!
Waiting for the the extra plug, to use the two extra wires, and the T-taps, so I can make the swap.
1 - 20 of 20 Posts
